I have a 07 Yamaha 4 stroke. My dealer sent my injectors off to be cleaned and rebuilt. Ran fine for a little while, then motor felt like it was missing but cleared up when I got on plain. Shut down and couldn't get it started. In fact it would turn over and shut down. Finally started but was running ruff. Got up on plain and it settled down however I started losing RPM and it started running ruff. Had to run about 20 minutes to get back to dock.
Turns out, one injector ha filled up my cylinder. Pulled plug and gasoline pour out of the cylinder. Waiting on new injector.
Worried that running the motor I could have seriously damaged the motor. I hate to tear the motor down to check it out but what other tests should I run to test it. I know a compression check should be run. Any other suggestion. I feel like the injector company should be responsible for any damage. Any advise would be appreciated.
