joshvette001
- May 22, 2011
- 22
Engine Year - 1987
Engine Model - Suzuki DT75
Serial - 07501-7077**
Carb in question - 3rd carb at the bottom
Problem - I being the idiot I am dropped the carb the wrong way on my workbench. The black plastic Carb Fuel inlet on the third bottom carb broke. The inlet that broke off is the main fuel one that takes the fuel from the pump to the other carbs. It is a Y shaped inlet that seems to be impossible to remove.
Question - Does anyone know of good places to find used suzuki parts. I have checked ebay, brownspoint, and other misc vendors online. I have sent requests to suzuki and others seeing if I can track down a used carb. So far I have turned up some carbs from older models but I don't believe they are interchangeable.
Any idea on if its possible to fix a broken fuel inlet? Can the carb itself be machined out and then a metal replcement screwed in somehow? If possible who would be able to make the actual inlet piece itself.
Thanks for any help you can give.
