mrsbaby1911
- Jun 14, 2009
- 5
Hello, first thread ever so take it easy on me...lol. Intermittently, my engine will rev to 1200 to 1600rpm. Yesterday, I was able to duplicate this condition on muffs. I suspect the on board fuel tank is the culprit because when I swapped to the small 5 gallon auxiliary tank, the problem disappeared. I need help determining what possible trouble could be with the inboard tank. My research tells me restriction causing lean condition but I can't find this exact problem in any existing thread. 2005 200 hpdi. Z200txrd. 90 model 20cc fish Welcraft. This happens in neutral btw. I also believe I can rule out sticky throttle plates because the problem begins immediately after start up.
