Re: 1989 50 hp yamaha starter
Clicking probably a weak battery or loose/corroded connection on battery terminals, ground, or on side of starter...remove/inspect/clean/ grease/tighten each one....if that doesn't do it then have your battery checked....what is the age of the battery?....the main battery cables can develop corrosion on the inside of the rubber/plastic cable jacket...check them out!
