Re: Yamaha 130hp 1998 too much smoke in only one of two.
Thank,s a lot for your help. Im using pre-mix. I was using for many years precision oil blend by Yamaha, but one of the line was not supplying proper oil and #2 cilinder,piston,rings, cranshaft failed.I did the power unit overhaul and eliminated the oil pump. Now i,m using pre-mix. Any advised is welcome.Thanks a lot for your time.:joyous:
