I have a 2008 Yamaha fuel injected T60 4 stroke on an 18 foot Koffler custom built boat. The engine runs great most of the time but it has been acting up intermittently over the last couple years but especially when it is at elevation (6000+ feet). That being said it hasn't been perfect, even at sea level, either. One shop I took it to said it was the injectors and cleaned them at a cost of $400 plus. It worked ok for a while and then began acting up again.
When it happens, the engine won't turn over 3200 rpm (give or take a tad) but the engine runs smooth. It seems to be running out of fuel but there is plenty in the tank and filters are new. Running clear 92 octane for fuel, never run any ethanol through it. Has new plugs, and doesn't change when the fuel bulb is pumped. Tanks are 6 gallon portable tanks in the front of the boat, hose running to the back under the deck, through a water separating filter and then to the engine.
Seems to me that because the problem is intermittent, it can't be a plugged filter. Screen in the fuel tanks is ok, tanks are clean.
Any suggestions? Thanks!!
