I just picked up an new boat with a 90hp Yamaha and took it out for the first time today. I left the ramp and got on plane and it was running great. I went through a no wake zone and got back on plane no problem. Went about 3 mile or so, turned around and went back through the no wake zone. I got back up on plane and it started running rough like it was dropping a cylinder or two. I nursed it back to my dock and made it there. I took the plugs out, which looked fine and cleaned them but it still ran rough and cut off. I then got a portable can of fresh gas with no change. I took the plugs out again and the top two were black, the bottom two looked fine. I got new plugs and no change. Tomorrow I plan to use an inductive timing light to see if I as getting spark to all cylinders, after that I am at a loss. Any ideas or help would be appreciated. The motor only has 42 hours on it. Luckily it is still under warrantee but I will have to find a Yamaha dealer if it gets that far. Thanks for any suggestions.
