Strainstress1979
- Aug 18, 2013
- 2
I have a 1999 Yamaha 200 V6 2 stroke outboard that i bought with my 20ft Make several years ago. I bought the boat with this rebuilt engine and just had service done on the engine about 1 year ago. The engine has been running like a champ until about a week ago. I was about ? mile from the dock when the motor started struggling to run like it wasn?t getting enough gas so i put it into idle checked the fuel lines and everything looked good. I engaged the throttle and went full out when it started to struggle again so i pull back on the throttle and as i was going into neutral the engine stopped and hasn?t started since. I thought it was an electrical or fuel problem. Checked the electrical situation and everything look good except for the starter so I replace that but the engine still wouldn?t start. I tried turning the flywheel by hand and noticed it make about 300 degrees of rotation and then would stop so i would turn it back in the opposite direction and again, 300 degrees and it would stop. I took out the spark plugs and tried to start the engine thinking I may have vapor lock but no success. It just won?t turn over. I?m thinking i have a stuck piston head in one of the cylinders and I?m going to have to re-bore that cylinder. Before I start I was wanting some thoughts on if my diagnosis is correct or if there could be another problem and how to check for it. Also if anyone has any comments about me trying to repair this myself. I was going to remove the powerhead and have my local machine shop re-machine the cylinder and then get a sleeve to the cylinder. Is this too big a job for a novice?
