Gradywhite3535
- Dec 29, 2012
- 480
My remote oil tank is slowly pumping oil to engine mounted tank. I want to check the screens/filter on tanks. I'm going to have to remove the remote tank in order to get to pump/fikter. This will be my first time doing this! Is there anything that i need to do other then basically take off filter and inspect? If the remote tank filter is clear i would like to take out filter from engine mounted tank. I see some post that say don't rip out that oil gauge assembly. Is this true? How do you take off the engine mounted tanks gauge to inspect the strainer? I once tried taking it off and couldn't so i didnt want to mess with it. The screens are # 6 and 15 correct?
http://www.**********/parts/search/Yamaha/Outboard/2003/130TXRB/OIL TANK/parts.html
Thanks guys
Thanks guys
