Hunter_1987
- Jun 9, 2012
- 8
I have a 98 25hp Suzuki that i'm having trouble with. When the engines cold it takes quite a while to start, almost runs battery down before it will run. I have choke pulled out while turning over but nothing helps. When it does start it idles real rough and smokes worse than ive seen most 2strokes while running. It runs great top end with no miss but when I return it to an idle it goes back to running rough, sometimes dies. It always starts back quick when engine is warm. I'm stumped on it, any help/suggestions would be appreciated. Things I have done- pulled all 3 carbs off and cleaned bowls and jets, checked compression on all 3 cyl- 110 on all, new NGK plugs, spark is good on all, new fuel filter and line, has new gas tank, also adjusted on the 2 idle air jets with no change. I was told that the Suzuki 3cyl always idles real rough but I have never had experience with them. Thanks in advance for any help..
