1998 115 Yam 2stroke. Had some bad gas. Got that all out . changed plugs ,and had it running I thought well.
Took it bout today to give it a run. At first ran very well ,after about fifteen minutes . It started bogging down .it seems to idle well and dose good at low RPM / speed. When you go to get her on plane she bogs down.
Looked for water in the fuel,didn't find any? I did notice that the primer bulb dose not stay hard . But if you pump it it dose not seem to make much difference. Looked at the new plugs,they looked okay.
I am sure that I will need to take apart and clean the carbs? Probably rebuild them while they are out? Sound about right? Or am I missing something else too?
Thanks for any advice or help.
Eddie
Eddie
