2003 250HPDI, blew #2 cylinder at 503 hours. The price when I bought the boat was low enough to justify another PH in the future, and more. My yard got a rebuilt PH from large well respected company that only sells to dealers. All the oiling upgrades were done before I bought it. I went over board on the break in of the PH.
At 580 hours, clank, clank. Cylinder #5 had 0 PSI and 6 had 35#'s. PH removed and sent to the rebuilder, who I spoke to on the phone. Not covered under warranty as the #5 piston has a hole in the top, indicating, they said, an ignition/timing problem. The #6 issue was debris from #5 getting into it before it all exhausted. They were very helpful and are repairing the PH and shipping it back to the yard for $750. The repair place that put the first one is no longer in business so I am dealing with another yard this time.
My utmost concern at this point is that the issue does not repeat with the new PH. What would cause the burnt piston and what do I need to do to fix it?
Also can you premix oil during break in without clogging the injectors? During last break in the oiler was increased and oil was squirted into each intake every 1 - 2 minutes for the rebuilder. No premix and I left the oiler as it was, never cut it back.
Thanks in advance.
Thanks in advance.
