desertfox0118
- Apr 3, 2013
- 8
Ok, first off i've done the search of topics and couldn't find a specific answer on my issue. Lots of ideals on what to try and i've tried them and still want to be sure before i spend money on parts.
I've got a 1998 Yamaha C150TX on a Cobia 19' CC.
My issue is that the tilt/trim isn't working either up or down. My issues started about a month ago, took the boat out then parked it with the motor down. The next time i was preparing to head out tried to tilt it up and nothing. Swapped the wiring at the solinoids, got a bump then switched them back. Got it up and worked it several times, took it out with no issues. Parked it for about 2 weeks with the motor up and now nothing except the click of the solenoid when i press the switch for up or down. I've tried most suggestions mentioned on other posts with no result so i'm guessing i'm down to replacing either the solenoids or the motor.
I appreciate any help as i'm still a novice at learning the in and outs of troubleshooting.
