Re: 86 Yamaha 70hp no compression in #2 cylinder
In order to get compression, you would have to have a seal between the rings and the cylinder. I've seen pistons where the rings were stuck to the cylinder to the point that they were flush with the outside of the piston (as opposed to sticking out past it like they're supposed to). In these cases, there would be a considerable gap between the rings and the cylinder walls. You would not have compression with a large gap between the piston rings and the cylinder walls. In a very healthy motor, there is a very tiny gap, and oil seals it. But in a case where the rings are stuck to the piston, the gap is too big for oil alone to do the trick.
There is another possibility... you may not be getting oil on the #2 cylinder. If you have oil injection, perhaps the oil line to the #2 cylinder is kinked or clogged somehow. You can try draining all gas from the carb bowls, fuel lines, filter, etc, and run the motor on premix (50:1) and see if it makes any difference in the compression reading. Or squirt oil into the #2 cylinder's spark plug hole and see if that gives you compression. I would do all of the above, and also check what's going on with the rings by peeking through after removing the exhaust cover.
