I have a 2001, Yamaha F115 with 1011 hours. Three times this summer in the last 40 hours of using it has been very hard to start. This happens after running normally and turning the engine off and trying to start within 30 minutes of stopping. Today I tried a new primer bulb, portable gas tank with fresh gas but could not get it to start. Also today when it would not start the warning horn was sounding while the engine was turning over. Six hours later I was testing the flow on the fuel pump and the engine started right up. Fuel flow was good, I connected the original fuel lines, and ran the engine for 5 minutes on the trailer with no problems. Any ideas of what to test or look for would be greatly appreciated.
Thanks,
Kevin
Problem solved. Answer posted on #26 in thread.
Thanks,
Kevin
