Re: Yamaha 115 no spark
Took stator and pulse coil to have them tested by local outboard mech. He says they are good.
He says to unhook main harness at engine ,the ten pin. Then to use remote starter to see if it will spark.
First question, where should I hook up the leads from the remote starter? I need to bypass the solenoid ,I guess . Red wire at starter,and lower wire at the series of wires that go up the side of the starter at the solenoid?
Second question , how fast should the starter turn? I have read that it needs to spin fast to create enough spark. It seems fast enough for me?how can I tell if it is fast enough?
Third. If this dose not tell me anything. If I test the leads from the stator one set should test 165 volts the other 45 volts. Would this reading be the same wether the kill was grounded or not? It seems it would not change due to a grounded kill switch wire,but I'm not sure?
Thanks for any help or suggestions
Eddie
