I need help guys. Yesterday motor was loading up and fouled plugs. Motor wouldnt start and had to paddle the boat back to the cove we are camping in. Luckly not far!! Today i pulled the carbs and cleaned, pulled fuel pump and cleaned, changed plugs, changed primer bulb, noticed fuel line was showing wear so i changed it. Motor starts easily and idles but "bogs" all theough the rpm range and plugs are starting to show fouled again. Pulled the boat out and started on the hose. Pulled plug wire on each cylinder to see cylinder drop. Driver side bank was more noticible than the other side but it was still a noticible miss. What should i try next? Clean carbs again? It was noticibly better since i cleaned but not running tip top. Possible i just moved the junk around inside the carb? We have 5 more days at the lake and are camping on vacation. There is only a NAPA auto parts store around where we are at.
