cleaned out VST tank and changed out small filter (which was clogged) under high speed fuel pump inside VST tank. All other filters changed. Problem is still occurring..
Motor needs good compression, spark, timing, and proper fuel/air mix to fire cylinder properly
if it is not fuel related then it must be spark, but have no idea about the 4 strokes
Normally you test compression, spark, & timing and if no problem is found you look at fuel
the newer motors need computer diagnostics maybe as they have more electronic devices
