Retriever1
- Jul 14, 2013
- 2
Good evening! I have a 2006 2 stroke 90hp Yamaha...............so about a month ago, I hit an underwater obstruction, mechanic replaced the prop shaft / bearing, replaced the water pump etc., but indicated no additional damage to the engine. First time out, the engine ran well, but sounded a little different. This weekend, the engine stopped while running almost as if it ran out of gas, restarted and ran again for 10 minutes. Did the same thing again, however when restarted, sounded like it was knocking, rough and didn't have enough power to get on plane, towed back to dock.
Mechanic checked lower unit oil, it was fine. Checked compression and the #1 cylinder tested at 25, the other two were I think 105 and 110.
So my question, could hitting the underwater obstruction have caused what is described above? I find it almost too coincidental from a timing perspective.
Thanks in advance for your input!
Take care.
Take care.
