Drop the foot again, and while turning the prop shaft by hand and shifting the splined shift shaft by hand back and forth "find" neutral....then put your motor control in the neutral position....replace the foot and you should be good to go.....when you really think about it, makes good sense!....a good rule is to Not move the shifter shaft while foot is off...
