spriessman\
- Sep 3, 2009
- 7
1986 90hp 2 stroke. Missing below 2,000RPM. Seems to be running on 2 out of 3 cylinders. 2,000 to 3,000RPM uneven power. RPMs surge, then dog down +/- 300RPM. Above 3,000RPM all seems good. Serviced 60 days ago for same problem while on vacation in Florida. Tech performed "100 hour" maintenance. Plugs. lower unit, impeller kit, $400. Tech writes "sea trail - found stalling a lot - adjusted carbs - ran at idle OK". Problem seemed solved - now it' back again - plus there is oil leaking on the transom mount and leaking from the lower cowl, down the left side of the leg. I pulled the plugs - look new from recent service, not fouled. Fuel is fresh marine gas. Any thoughts before I take back to the marina for another service??
