my 2000 Yamaha 50 will not turn over. has good battery. took out plugs and turns over. checked wires fr battery, seems ok. could it be the starter? whats the trouble shooting rout? ran fine till last w/e.
Does it turn with the key or manually with the plugs out? Be sure the battery is fully charged and the connections are clean. Use a test light to see if you are getting voltage to the solenoid wire with the key in the start position.
