Hi guys, I have a 1993 C55 2 cyl 2 stroke that appears to be double firing on #1 only. I have come to that conclusion because the tach on my timing light reads double on #1 vs. #2. Engine bucks and pops and will not idle. I have replaced the CDI unit, and have exactly the same results. I have pulled the flywheel, and swapped the two pulser coils, same results. I am now wondering about the trigger coil itself. I cannot see that as the problem, because (I think) it only generates voltage, and the actual pulse to fire the pack comes from the two opposing pulser coils. Very funny thing...when cranking at starter speed, NOT RUNNING, both cylinders read about 500 RPM on my timing light tach. This engine only double fires #1 when it is running. The minute it starts up, tach reads twice the RPM on #1 vs #2. Anyone experience double firing on this style motor, and what was the cause? The more I think about this, it makes me want to examine the actual wiring for frays, shorts, etc. I will do that today. But, can this trigger coil cause double firing? And, is it possible I am way off and it is not double firing? The fact my tach reads double tells me it is double firing. Anyway, thanks for any input.
