I just picked up a bass boat with a 1993 Suzuki 2 stroke 140hp outboard. The motor initially started fine but idled rough(hiccupped) after it kicked down off of the fast idle. I then turned the knob to make the engine idle faster and it immediately died. Now it will barely idle after the fast idle kicks down and usually dies within 10-15 seconds(it never died before I turned the knob). With the knob back in the original position it still dies and hiccups. Compression on all 4 cylinders is 130 +/- 5psi. Engine runs much smoother and doesn't seem to die o hiccup as much when the #4 plug wire is removed. #4 spark plug was dark brown/black and I have replaced all spark plugs with new, same problem.
Could this be a carb issue at the #4 car or something else? I also switched the coil from #3 to #4 and the same hiccup occurs.
Also the water outlet stream seemed to stop so I shut the motor down, turned it back on, brought rpms back up, stream came back on but stopped the next time I started it. Also the water coming out is hot and you cant let it run on your hand...do I have a water pump issue?
Any suggestions??
Any suggestions??
