I've got a 1989 25hp Yamaha autolube. It fires first or second pull and I can get it to full revs in neutral. When I put it in gear it'll idle fine, but struggles at speed. It'll run for a while, but not at full revs. It sounds a bit like it's running on one cylinder.
I thought it was some kind of fuel issue. I've changed the spark plugs. Cleaned out the carb (it seemed clean). Cleared out the bowl filter which was clear anyway. I've tried pumping the fuel in while it's running, but the ball stays hard and it doesn't make any difference.
Could it have anything to do with the oil? Should I try running it on mixed fuel?
Thanks in advance for the help.
