tightline123
- Mar 20, 2012
- 3
My motor will usually crank right up and run great first thing but then when ever you stop and try to crank it up again it seems to not have spark and will not crank. Some times it takes 5 min and some times 5 hours to start. When it does start it fires right up and runs great. Usually after it does that one time on the water it will start and run great for the rest of the day. I have disconnected the kill switch thinking that was the problem but still have the same results. Any help would be great and thanks in advance.i feel sure this is not due to flooding of the motor as when it does fire it runs great with no smoke. I've checked all fuse and they look fine as well
