About a month ago I bought a 1992 115HP Yamaha 2 stroke outboard motor. It has been hooked up and seemingly worked ok. But every time I go over 4000 rpms it starts to lose rpms and won?t really go above 2000 rpms again. The oil well in the engine?s float was stuck at the top. I replaced the float and the oil now correctly transfers from the boat oil well to the ?in-engine oil well?. I constantly check the cyclinders to see if they are hot, and they never feel abnormal. The pisser seems to have a constant stream as well. The only problem I can identify is that there are 4 wires that do not have corresponding wires to connect to.
Yellow wire- the yellow wire is connected but there is a spliced wire sticking out with a male connector that is not connected to anything
Yellow w/ red stripe: this wire is coming from the engine and has no wire to connect to
Black wire: when connected to a volt meter testing 12v it shows a high number like 80. It is in the same group with a pink and orange wire. I have attempted to attach it to another negative, but no difference.
Orange wire: inside the engine
I really just want to be able to fish and can?t seem to figure out why my engine is apparently going into ?limp mode??. The boat starts up and seems fine until I push it past 4000 rpms. The oil float works and the manual switch. I have cleaned the carbs best I know how. Any input would be greatly appreciated
