Suzuki DF70 trim problema
manitoba1
I started having troubles with the trim on my 2000 Suzuki DF70. Can't trim up with the trim control on the throttle lever although I can trim up no problem using the button on the side of the engine. Could it be a faulty trim switch in the throttle control. Noticed it happened a couple times briefly last season the suddenly today it stopped trimming up but then occasionally would work again. I pulled the boat home from the lake and no response from the up trim on the throttle. Any suggestion for a plan of attack. Maybe someone has had a similar issue? Any suggestions would be appreciated.
