Fuel supply issue to the carb, must use manual choke to start after short stops, and engine wont run after 1/4 tank of gas is left in it. No visible leaks in hoses or gas smells. Motor runs at full speed to idle, but has the above symptoms.
1. the primer bulb is always mushy, will not get hard.
2. fuel level inside the fuel filter goes up and down while squeezing the bulb.
3. replaced the fuel tank pickup, has a clean screen.
4. ordered a fuel pump, plan on installing it.
5. Fuel filter is clean.
6. Ran high concentration of sea foam in gas to clean system, no improvement.
