pine island fred
- Dec 20, 2002
- 1,144
Have a YAMAHA 50 2 stroke, 50TLR, manufactured MAY 2008. Has been in the box until I had it hung last JULY. Wanted to use it before I died but the 50 MERC it was to replace never quit. It ran sluggishly for about an hour last JULY. Due to health reasons I was not able to use it again until my attempt last weekend. The think reeked of stale fuel and understanbly refused to run. It has carbs, which is the reason I bought it, so I took them off to clean them.
This is something new to me as it has no choke or choke solenoid. The 703 controls do have a press to choke which does not do anything and the owners manual says absolutely nothing about choking. There is also no idle mixture adjustment on the carbs BTW. At any rate the center carb has a gismo attached to it with 2 wires, called an EMERGENCY STARTER VALVE. The owners manual gives very little info on it except moving a small lever on it from open to close for cold engine start.
Can someone tell me exactly what this valve does and what controls voltage thru the 2 wires attached to it. The motor still runs like hell so I am going to have to dig into it more. Perhaps a gummed up fuel pump. Thankyou FRED
