Re: FT50 Yamaha overheat?
You will find that the 2 small tabs pressed into the cup are pressed flat as well as new indentations pressed into the plastic housing. Gain access to view the pump outlet, there should be no stainless steel visible. If you see steel over the outlet, the cup is skewed. More common than you may think. At this point, what do you have to lose?
I do not know about 50 4 strokes but V-4 2 strokes have a pressure relief valve under a housing cover. Is a spring and disk that corrode in salt water, if you are in salt. regards FRED
