Suzuki DT75 Dies at half throttle
12RIVERRAT
Suzuki DT75 #07501-403838 Dies at half throttle also stalls coming to dock & trailer. Had carps rebuilt last year. Did compression test all good.HELP
mphelle8vld
Re: Suzuki DT75 Dies at half throttle
Using the info provided, I would check the timing and clean the carbs. Do you have a manual for it?
James R
Could be a whole bunch of things but if the motor starts ok and runs well up to half throttle I would look to the fuel pump or the fuel pick up tube. An air leak in the fuel line could also be the problem.
Quick test. When the motor starts to fail pump the primer bulb. If the motor picks up then it is a fuel problem not ignition.
