Natty Light
- Jun 11, 2012
- 120
At full throttle the engine loses a bit of power and then goes back to full power. It repeats this pattern as long as the hammer is down. When running at half throttle or less there is no noticable issue. The problem only occurs at 3/4 to full throttle. The engine never shuts off just seems to bog down for a second and then comes right back up to full power. My buddy suggested it was the fuel filter. I unscrewed the bowl and saw there were a several small black particles floating around. I dumped them out and screwed it back on. This seemed to fix the issue tempararily, but i noticed the symptoms creeping back after another day of riding. Your thoughts? The engine is under an aftermarket warranty, but if just adding a new fuel filter is the answer I would rather attempt that than spend the time taking it in. Any thoughts or advise would be appreciated.
