I have water in my lower unit lube on my Yamaha OX66 200hp motor. It is due to a bad drain plug gasket, and the motor has only seen about 3 hours total run time since the lube was changed, which is when the leak began. Boat is hoist kept and when I noticed an oil film on the water I investigated to find some leaking from the plug hole. I opened it up to replace the gasket and found that the brand new lube put in a month ago was creamy looking. My question is this, in three hours of runtime... how much could I have damaged the lower unit? The lube that came out is still thick and feels/smells/looks clean and new except all frothy. Seems to have its viscosity or thickness. I was thinking of just flushing and refilling with new. Did I dodge a bullet by detecting it so soon or am I in trouble?
Any advice is much appreciated!
Thanks.
Thanks.
