shackle101
- Jan 11, 2012
- 140
Hi all so I'm rebuilding the carbs and I trying to figure out the service manuals recommend float height. I assume it means 19.5mm, but that's too high to be possible. I've attached an image can someone explain to me how to read these measurements correctly? Currently the carbs leak when lifted up so I assume this is the reason why? Also noticed my spark plugs have a bit of oil on them could the float height be the reason why? The Compression is fine.
Thanks!
Thanks!
