The P-hole on my 2000 DF140 appears to be clogged. (The pump impeller was replaced just a few months ago.) Can anyone tell me how to remove and inspect the P-hole fitting? Thank you in advance.
Stick a length of monofilament/weed eater line into the hole with the motor running....could be a spider, wasp or other insect built a nest in the hole...it happens all the time.....
