ok, so my neighbor went to florida and bought a used engine after his old one finally bit the dust.
he went from a 1986 175hp yamaha with 150hp carbs on it (old DNR engine), to a 1993 200hp yamaha. we got it mounted the other week and cranked it up after tossing new plugs in it. ran fine but sounds like it doesnt want to redline (I think it does, he doesnt).
anyway, you could tell the top carb was recently either rebuilt or replaced. he popped off the other carbs and rebuilt them, the middle one was kinda clogged up. tossed them back on after rebuilding them and it sounds just the same. It cranks instantly and idles fine, part throttle seems good, but the high rpm doesnt sound like his old engine did.
he doesnt have the manual yet for the new engine so we just used the one for the old engine. obviously not sure if the specs are the same but it was saying for the 200hp engines you want timing at ~7ATDC with the side lever pushed in (cant remember what its technical name is).
On the new engine, there's a mark at around the 20* point. anyone know what this is for? is this where the timing should be set? also, that is the ATDC side? there's no markings other than a couple "TDC" points.
anyway, we cranked it up and let it idle and checked the timing. these are while it was idling.
without the side lever pushed
if the first pic with the little paint arrow is correct with that side of TDC being ATDC, then the third pic tells me the timing is definitely off. If not then it looks pretty spot on to me.
any help would be great, thanks!
and yeah, I'm trying to get him to get me the model info from the new engine but we're both working right now.
