1990 225 yamaha 2 stroke no power under load
davidkuehn5
i have a 1990 yamaha 2 stroke 225 outboard on a 222 aquasport center console, it cranks up and runs great in neutral and in gear when on the water hose. when i put it in the water it will idle and go into gear just fine but boggs down terribly when in gear, at full throttle i can only get 7 mph. i have a 14x21 prop on it. i cleaned the carbs, replaced all spark plugs. all plugs are getting spark. i have an external tank hooked up with fresh fuel. i dont know what else it could be that is causing the lack of power. any ideas?
also.. i took off the air box and i can see fuel spraying out of the every carb into the cylinders. so i believe im getting proper fuel i guess????
99yam40
Re: 1990 225 yamaha 2 stroke no power under load
Check to see if timing is advancing to spec and test alarm system to see if it is functioning.
You may have an alarm coming in but the buzzer is not sounding
99yam40
with a timing light just like on your car or truck
davidkuehn5
Okay.. i found another issue that is probly the cause... when i pull spark plugs one at a time and listen to the engine sounds, the top two cylinders dont affect the sound of the engine when i pull the spark plugs... what could be causing me to have two dead cylinders???? i have compression, clean carbs, new spark plugs, spark to the plugs, fresh fuel in portable tank.... what else could it be??
SwillFish
Your CD unit may be going out. Sometimes a bad unit will still give off a spark, but won't properly fire a cylinder.
