Hi folks
Was hoping someone can help with the testing of MY Fuel injection pump, I have a Yami 1997, 225HP TXRV ,Initially the problem was intermitent cut off,s then the engine was taken in were all the filters and the 3 diaphragm fuel pumps were replaced , along with the filter inside the vst tank , compression on all cylinders were also good. At this time the engine will turn over and crank if shot with starter fluid then cuts off as if no fuel in the injectors ,( dont like to do that to often cuz no oil may cause a serious damage ) I would like to know how i can check the voltage to the pump and what range it should be befor i shell out 800+ Bucks for the pump. anu help will be greatly apreciated
Thank you ,,, Walt.
Thank you ,,, Walt.
