may have a no pull start when in gear device. will have to pull cowling off and look to see what is going on
Remove spark plug and turn motor over by hand using the flywheel...check for water, oil or fuel in the cylinder....
so I pulled the spark plugs. No oil, water or gas in cylinders. What is no pull start
