I replaced the h20 pump with a oem kit (didn't replace the housing). Before the replacement the old pump was working good . Now the pee stream is weak and overheats. Upon inspection the "o" ring that goes on the bottom of the housing looks too thin and will not seal the housing against the wear plate. Anyone else experience this? I have the lower unit off 6 times trying to fix the problem.
popit, stats replaced.
thanks
Craig
thanks
Craig
