I, have a yamaha 115 outboard, its on an 18' hydra sport has a 13x19 prop, it runs somewhat good when I, got it, but seemed to be a little slugglish as the original seller said he had the carbs rebuilt, it appears to have two duplex type of carbs with adjustment screws on each side of the carbs, I, checked the setting on the mixture screws and there 3 1/2 turns out on the STB side and 2 1/4 turns on the PS side, upper and lowers equal, the engine runs ok at idle but seems to dog down going from idle to mid throttle then it recovers and runs up to 5500 rpms its just in the lower and mid range that is has the power loss, or when you try a hole shot, I'm an ok car mechanic but not to sure yet with outboards, and need some input on the fuel screw turns, Thanks any help greatly appreciated.
