2002 Yamaha 25hp 4 stroke getting hot on the muffs.
Pas Bon
Sucked up a bunch of mud last winter and it went into limp mode for the first time ever (I assume it got hot) shut it off and restarted it and it ran fine.
I ran it in the yard today, had it at a high idle for a while and notice it sounded funny after while, tried to rev it up and it would spit and miss (limp mode). Strong stream out of the tell tail (pee stream) but it was quite warm. Touched the thermostat house and it was VERY HOT!!.
Shut it off and restarted it and it ran fine.
I have never changed the thermostat
Water pump is not that old and I think since it seems to have god pressure that's not it.
So could it be the thermostat?
if not what could it be?
Thanks in Advance!
P
Pas Bon
Re: 2002 Yamaha 25hp 4 stroke getting hot on the muffs.
I found a bunch of junk behind the thermostat, old grass, mud and bits of rubber from an impeller, either current or old, I'm not sure which, but I expect I need to take a look at the impeller!
