jack daniels marine
- Jun 27, 2012
- 48
I plan to touch up some corrosion on my 1997 DT40 soon.
Can I use a proff. quality automotive clear coat spray can or should I find a clear coat specific for marine use?
The corrosion is on the lower unit under the water line. I will probably use a dremel or similar to polish it off.
I have purchased Yamaha spray can primer and Suzuki top/color coat.
