Re: Yamaha 150 hp 4 stroke
It is normal but you are not shifting correctly. The idea is to NOT to slide the thing into gear. Shift it with authority. Every time you slide it into gear that ratcheting noise is adding wear to the clutch dogs. Pop it into gear and you will not hear the chatter.
