Re: Yamaha 130 compression
Thanks !!!
I found a third 130. Compression high, but uneven on the 2 lower cyls. 148-150 on the 2 top cyls and 135-137 on the 2 lower cyls. (Interesting that top 2 are the same and the lower 2 are the same. ) I know about the 10% rule and this is right at or slightly below and that compression testers vary, but, supposedly the motor has not been used in at least 8 years and looks great!
What do you think??? Lake testing is out - motor on a rack and I did witness the compression test.
Mechanic who is selling motor says it has not been rebuilt - just some carb cleaning.
Thanks ......
