Re: Which 25 hp Yamaha do I have?
what service manual do you have?
an after market one that covers all HP and many years of production?
I would think that a Yamaha service manual for your model # would give you all the info, it will cover the motor that was built that year.
and I do not think they build multiple different 25 hp motors with that model #
And what is it you are trying to do that you need this info?
It is an aftermarket Seloc (sp?) and does cover all. This may be the problem. Most of the spec charts, with the exception of one, do list two possible sizes. If it was just a misprint, doesn't look as though it would be in several different charts. The one exception that listed only one was the ignition chart.
I did not think they would build two motors with one model number, but there's no distinction in this manual.
Specs on setting the carburetor (hey! I spelled that right first try) differed in setting the float. It was close, but not the same. We just split the difference. Seemed to work fine. Hopefully, I'll have it in the waterway next week and know more about how it performs.
If I don't run into anything else, it's sort of a moot point now. If someone had a Yamaha manual and a spare minute or two to check, I'd appreciate it. And it may never matter again.
I just really thought someone might know off the top of their head.
Thanks to all,
John
