Re: Yamaha 50 TLR 2 stroke power problem.....no power off idle e for10 minutes then r
I will go back to the manual and re-check the link / sync to make sure I didn't miss anything. Will also take another look at the prime start assy. I did flip the lever while on the water when the boat didn't run, and no change. I did not check the solenoid valve on it, but saw the procedure for testing it. Red lever is in normal position.
For the record, maybe I should add some more history to this motor. Its kind of strange, and a bit long, but you may read something into it that I am missing...
I bought the boat a few months ago from a nice old guy that really didn't know anything about boats, and had nothing but bad luck with this one apparently. Its a 98 model Xpress, that he originally bought equipped with a 60hp Yammie. He got taken, as he shortly thereafter learned that the motor had a cracked crank case that had been patched with an epoxy. The repair was going to be so much that he decided to buy a used 2006 50hp from an outboard repair shop, and do away with any problems with the old '98 model. They did the motor swap, but kept the original 703 control. They threw on an old prop that I doubt seriously was pitched correctly. The guy had several issues with the new motor, mostly around carbs. This was easily explained, as the hoses were rotten. He also had the prop spin, and supposedly pitched (but I know where he had this done, so I have my doubts that this was correct). He finally decided to sell it. He told me that he actually had it sold, and that he and the buyer took it to the water for a test run. He said it ran fine for 5 minutes, then just quit and would only idle, so he idled back to the launch (and of course didn't sell the boat). When I found the boat, the poor guy was disgusted and sold it to me "not running" (it would crank up and idle though). He told me that his mechanic was suspecting the CDI unit may be bad, and he wasnt willing to spend the money on it. I asked if I could check a few things, and checked compression, and foot oil, and looked at the general condition of everything. The boat was in rough shape, but the motor problem seemed pretty simple, and I got it for a song.
I got it home and hooked up the ear muffs, and noticed right away that it just puked water out of the telltale, so I got to thinking that perhaps the motor had just gone into "overheat" mode, and allowed him to idle home. I changed the pump, then pulled and cleaned the carbs (you could tell they had recently been gone into), and discovered the typical ethanol hose rubber in them. I replaced the hoses, and thoroughly cleaned the fuel tank (did everything but the fuel pump). I then proceded to re-do the entire boat, so I pulled the motor and gutted her. Worked on it all winter, and have now finished it and hooked everything back up.
I crossed my fingers, but really expected to not have any problems with it. First time to the water, it did exactly what the guy said, it would not run over 1100rpm without dying. My son and I messed with it for a few minutes, then just fished for a while. When returning to the landing and after idling for 10 minutes, I tried the gas again and it took off, but would not plane. HMMMM... When I got home, I thought about the fuel pump (and wished I would have pumped the bulb while I had it in the water), so I pulled it and checked the diaphragms & checks. No punctures, but I didn't like the way the rubber diaphragm felt (kind of brittle feeling), so I ordered a new pump .
Following weekend, I took it back to the water to try again with the new pump. Same thing. Kept trying, then 10 minutes later she tried to plane off. This time, I told my son (we are both big guys) to get up front, and it planed off. I ran it up, it ran fine but would not get above 4500rpm. The speedo said it was doing 35mph, which was the same top speed the guy had told me it would run when it worked for him (it was reading 35mph, but I estimate we were actually going about 28-30, the speedo is definitely not honest. Since that's not far from what I really though the boat would run, I assumed that the prop was severely over pitched. Keep in mind that the guy I bought the boat was pretty small, and the boat had a whale tail on it when he had it which probably helped it plane. I called the guy from the water, and asked him about how it came out of the water for him. He replied that it wasn't quick, but it did plane OK, and we both agreed that this may have been the whale tail. (the boat has 3 big batteries in the back too).
In the 10 minutes I talked to him, we floated down the river. Then when I started the boat again, it was back to not running off idle. After a few minutes, here it goes again! We shut down and fish for an hour, then same thing on way back to launch.
I hope it is fuel related, and really think the prop is over pitched, but I don't think thats the problem that I am experiencing, or the boat would never have run for the guy. I am confident that I rebuilt the carbs correctly, I have done a few. I guess there is a possibility that there was some crap in the fuel pump that contaminated them again right away, but I think that unlikely.
Long story, but I thought I should tell it to help in troubleshooting. You now know everything that I can think of about it. LOL..
Thoughts?
Thanks,
Rich
