Hi I have a 1993 Yamaha 175 HP 2-stroke motor (BETO NZ model) which has developed an irritating problem.
The alarm buzzer goes off after about 2-3 minutes of running at around 4000-4500 rpm (upper revs).
Unfortunately the standard multifunction LCD displays (MFD) dont show any cause, not even a fleeting apparance.
(On starting the LCD display passes its self-test)
As one would expect, once the alarm buzzer sounds the motor revs are automatically cut.
I always throttle back to about 1200 and wait for the buzzer to stop by itself.
Each time this happens the buzzer consistently sounds for approx 38 seconds, (probably a programmed timed period regardless of issue?). Once the buzzer has stopped I can throttle up again and get another 2-3 minutes at the 4-4k5 rpm end.
If I run at lower revs say 3600 I usually dont get any buzzer action and all is fine.
So the first problem is:-
The motor protection circuits are activated as evidenced by the cutting of revs but the MFD doesnt show the cause.
A protection sensor that is wired to slow the motor in this built-in controlled fashion surely should be displayed but it isnt in my case.
Oil levels in the upper and lower tanks are all fine, the top-up proceedure works fine besides the level alarms would show up on the display,
The temp warning indicator on the MFD doesnt activate and the tail tail water stream is strong although I understanmd the take-off for this is prior to the cooling water heading through the head.
While there is no 'engine overreving' alarm indicator the motor can run up to about 5500 flat out. 4500 is just faster criusing (~35knts)
I want to take a methodical process of ellimination approach so any considered ideas would be welcome.
Thanks
E
Thanks
E
