2004 F75 4 stroke-300hrs.-/while running I noted low voltage (12.2) on dash volt display. Checked generator input to Batt. at about 7amps.Realizing generator rated at 25 amp output and usually kicks volts up to 13v plus, Increasing rpms decreased voltage to 12, then at lower rpm increased to 12.4. Cleaned all batt. connections and batt. all seemed good. In checking posts I note that diodes and regulator mentioned as cause for low output. Any advice of process (manuals,testing etc) would be greatly appreciated. Thanks, Vern
